181 - 200 of 455 Posts
2000 Excursion with 270K
2 alternators
2 water pumps
Idler pulley
CPS
Ball joints,
LF Wheel bearing
Rear Diff - Rebuilt - bearing
Brakes/rotors
Tires - on 4th set
164K.. dont know what previous owner did but what ive done.. front calipers/brakes, rear leaf springs, 2 u joints, tires... front end brake line, rear brake line (next to tank).. batteries.. think thats it
Front end rebuild
CPS
Shocks
Ujoints
Caliper bracket
Transmission line
Reseal kit for fuel bowl
1 alt
2 Staters
1 water pump,thermostat and housing
Shifter replacement (wire broke at base of shifter)
Temp sending unit
Replaced auto lock hubs
2 set of batts
Regular stuff fluids, rotor,pads.
Heres my list as of 143000 miles-- alternator, ac compressor, radiator, sway bar end links, ipr, cps, front & rear brakes, heater hoses, radiator hoses, t-stat housing, rear u-joints, shocks, glow plug relay and tires. All within the last 28,000 miles. Now at 165,000 I can add front axle seals, passenger side axle u-joint, sway bar bushings, icp and ipr sensors, uvch drivers side, hpop orings again, and clutch pedal assembly.
227K
1-Waterpump
1-Valvecover Gasket
1-U-joint
1-Alternator
2-Batteries
1-Transmission at 205k
1-Rearend Bearings at 210k
Brakes have been replaced three times up front (front rotors once) and twice in the rear. (no rotors) All belts and hoses have been replace as routine maintenance.
It has towed heavy and often its entire life.
Just add ball joints to the list at 255k.
bought it with 166000 on it. since i've had it -- tires, brakes, door locks, icp, oh yea and an engine(that was at 190000) now have 192000 or so.
bought my truck 11/2007 with 299750 km. $" exhaust, AFE stage 1 intake
since then (all in km):
301389 CPS recall
302081 repair OHC display, loose resistors
302274 switch pass airbag
305871 U-bolts rear
306827 ball joints and front brakes (rotors and pads)
308113 parking brake cable assembly
322551 starter
326676 glow plug relay
329074 started using veggie oil as supplement
332000 ish brake line rear
333674 rad, water pump, belt, idler pulleys
339314 front bearing hubs
342309 front brake calipers
342972 rear brakes: rotor, pads, caliper
347770 edge evolution
348283 new batteries, hutch mod, harpoon mod
348550 stancor glow plug relay
352145 track bar assembly and bushings front and
362075 air filter sock
364150 front shocks
364250 rear shocks
370000 km and counting still going strong.
Just replaced the two remaining original injectors #1 and #5...still goin!
What the 632,000 mile secret ? If my injector go that long ill just grin :)
impressive
I have replaced a couple injectors twice. I was surprised myself as I keep a log of all maintenance I do on the truck. The only injectors that had not been replaced were #1 and #5 and both recently failed the 'buzz' test after experiencing a rough cold idle. There is no real science. I have never used a fuel additive or have I overly maintained the truck. Some of the same people that swear by fuel additives swear not to use Fram filters...the only filters, both fuel and oil that have been used on the truck.
67,000 miles:
Just had the CPS recall done last week
Replaced original batteries this summer
Replaced original pads (front and rear) this summer
Replaced original rotors (front) this summer
On my third fuel filter (including original)
That's it. About half of the miles are towing.
170K miles.
Ford AIS broke lid tab on original lid 55k
Cluch - Spring on plate came out. 101k
throw out bearing
clutch fork
pilot bearing.
water pump 125k ,added coolant filter,and thermostat w/ housing
Batterys every 4 years
up pipe donuts 101k
hpop o-rings 101k
shocks 65k
brake pads front 110k -caliper hung up ,rear 130k
Tires
Clutch hydraulics - under warranty40k
UVC harness 101 k
door lock solenoids 110k
hydro-boost actuator 135k leaking.
fuel filter drain O-rings 125k
My most recent update:
300,000 miles: Driver's side caliper bracket with rusted solid slide pins, passenger side slide pins.
304,000 miles: New 4R100 transmission and flexplate. This is the original transmission, anyone got more miles than that on the original?
Since I owned the truck in June, I've done the following major repairs all at 215k. Previous owner neglected the truck apparently, but I guess you can say I got a good deal :)
* Oil pan
* PS Pump
* IPR and ICP
* Steering gear
* Front hub
* Rear springs
Bought new in 2002. 130K so far
> Power steering hose & pump
> New Power slot rotors and pads at 100k
> original trans
> New alternator and yellow top batteries
> New shocks
> about to replace ball joints and maybe steering box.
Truck is all stock, hopefully adding new exhaust and open airfilter
What is the best exhaust and air intake out?????
149K ball joints, brakes, batteries, water pump, crankshaft positioner, fuel drain valve, tires of course, super chip installed 19 MPG empty, 11 - 13 towing at 65MPH.
167k, truck in sig.
Balljoints, wheel bearings, rotors,various other crap.
motor hydrolocked due to coolant leaking in through #8 cylinder wall. Evans Coolant failure on my part.
Building new motor.
96000 miles. solenoid shift control at about 5k miles, #8 injector tsb 002201 (cackle), rear speed sensor, cam shaft pos sensor (recall), rear diff cover, speed control switch (recall). Other than tires and routine maint thats it.
1996 325,000
water pump
1 set glow plugs
1 glow plug relay
2 belts
3 idler pullies
1 vacume pump
1 valve cover gasket and under cover harnes
2 sets batteries
4 alternators
2 sets of ball joints
1 set tie rod ends
3 sets of tires
3 sets of front brakes
2 sets of rear shoes
new tranny at 300,000
rear axle rebuild at 297,000
1 set of head light bulbs
1 tail light bulb
a few marker lights
And still fun to drive
and for the really long list - what have you had to do to the 6.0?
