201 - 220 of 455 Posts
and for the really long list - what have you had to do to the 6.0?
this is not nice:nono:. I would like to see the long list - for comparison:thumbsup:.
Early 99 new with .5 klm on the clock Just shy of 600,000 klm now...
clutch twice
alt twice
ball joints third
tires five or six
cam sensor
and some small stuff
but the motor has never been touched :)
scanning through everyones posts ford should use this as a sales ad for there trucks. it seems the average mileage to be 150,000 for repairs.
bought at 30,000 miles. mileage now is: 127,000
the needed list
front calipers.
left rear caliper mount bracket.
two sets of brakes.
one cam position sensor.
front and rear shocks.
steering stabilizer.
front 4wd hubs.
power mirror switch.
all four door ajar switches.
glow plug relay.
plug to ac compressor.
left rear turn signal bulb socket.
3 directional marker bulbs.
3 cab light bulbs.
1 fog light bulb.
batteries.
serpantine belt.
the preventive list.
replaced thermostat and flushed coolant.
changed power steering fluid.
changed brake fluid.
oil changes.
grease it.
changed upper rad hose to the outer belt design.
that might make some owners remember the day they handed there 7.3 keys over to the sales guy and drove off with that new 6.0. wishing they never traded keys that day.
2000 F-250 SRW Crew Cab 147589 miles
3 sets of tires
Ball joints
2 CPS
1 alternator
1 Pilot Bearing - new clutch disc and pressure place while I was there.
1 set of shocks
1 steering damper
1 rear pinion seal
Newest repair 1 - IDM
Not bad for 10 years
2000 F-250 XLT, SRW, 2WD, SCLB - 101370 mi
Bought new in Nov, 2000.
1 serpentine belt around 45k - no failure, just preemptive "insurance"
CPS - recall
Sway bar mount bushing
New batteries in Aug, '97! (Should have bought new Motorcrafts after that kind of service)
New tires at 55K-getting close again
Injector seals at 100594 mi. Probably not typical(?) since I installed non-stock seals when I did Kim Lux no-cackle injectors in '01.
Water pump at 100594
Something sounds loose in the front suspension...will need attention soon
Recently achieved 21.1 HONEST mpg (full tank's worth). I drive at 2000 RPM on the interstates.
It'll probably outlive me -I'm 66
99F-350
199,000
Replaced glowplugs last week, under valve cover wiring, and gasket. 78$ per side for the harness and gasket from NAPA(It's a new part they just started carrying with wiring already hooked to gasket). 120$ for the plugs. Did it myself.
Replaced Water pump and thermostat last week, 156$
Replaced pads and front rotors twice.
Camshaft positioning sensor
Alternator.
Balljoint.
Three sets of tires since I bought it with 82,000.
Had someone else replace the water pump at around 90,000. Huge mistake, they did a crappy job.
The 6.0 list?
bought that one with 89,000 on it
2 IPC sensors
1 engine wire harness
1 FICM
1 injector
1 fuel pump
1 fan clutch
1 alternator
2 batteries
Needs a new Oil cooler as soon as I can get to it
2 new front intrical hubs
1 new tie rod (end to end)
1 set rear tires
2 sets front tires due to the tie rod problem
2 sets of rear brake pads
3 sets front brake pads
1 set rotors all around
it now has 198.000 on it
Keep in mind I bought the 96 in 2000 with 138,000 on it
I bought the 04 in 06 with 89,000 on it
then look at the list over 14 years on the 96 then the list over 4 years for the 04
I drive 102 miles round trip to work everyday
and that does not include the fact that the fender brackets for the dually fenders have rusted off on the 04 and other things and the 96 will out run the 04 any day
141k front brakes, rotors, both front hubs, fan belt just because, coolant resivoir tank, Lines to locking hubs, injector cups, rear end yoke and u joint, 3 batteries, door lock actuators, sway bar bushings, 3 sets of tires, about to install a new trans and tc this weekend. Drive like grand ma and best I ever got 18.2 mpg. normal 17.3 mpg towing 8k rv 10.8- 11.3 mpg.
109k, 2 alternators, rear pinion seal. Ball joints and left front hub under warranty at 32k. Ball joints are still good. Has original batteries, soon to be replaced. Sway bar end links front and bushings. Otherwise normal upkeep.
At 105k had cracked injector cup(s). That set me back a few bucks. Still need to flush cooling system for the third time. On 2nd set of Revos.
146,000 cps,waterpump,upper/lower ball joints,rear pinion seal, front calipers and rotors,hubs twice,brake line along frame rail,tranny,tailgate latch,buttons for door lock and windows,batteries twice, and a pcm.Body rusting behind driver side super cab door despite meticulous care.
230k
First thing I did was an AFE air cleaner, 4" exhaust, and Superchip (80hp)
Rebuilt Tranny at 80k, (3k for the hardcore rebuild)
CPS (of course)
Front Rotors
Glow Plugs (didn't really need it, but did it anyway)
Belt Tensioner
Ball Joints and Tie Rods
Left Front Hub
Shocks (Bilstein)
Rebuilt Turbo (from Rons Turbo)
I just took it in and had the some scratches and dents repaired and now it looks brand new!
mileage and repairs
I have 129380 on my 2003 F350. So far I had the transmission rebuilt in 2006, the transmission replaced in 2009, four cam shaft sensors, rotors replaced all around at 110000,and one speed sensor(recall) replaced. Then the general maintenance which includes oil and fuel filter replacements, two sets of brakes and one set of tires(not bad). I did find out today to not buy cheap rotors. Save up and buy nice ones because the cheap ones warped in less than 20,000 miles:dead: Also nobody ever has told me about evacuating the oil out of your HPOP. I did it last night for the first time and the oil looked bad and that is after recently changing the oil like normal.
Purchased at 114,000. Now 120,000. Since I have had it:
Starter, CPS, Fuel filter element, oil change.
Update
Now have 150,000 miles. Add 2 batteries, tires, brakes. I have a set of Michelin XPS M/S and Bilstein shocks and steering damper ready to install.
99 F 250 4x4
680,000
2 Transmissions
1 water pump
3 fuel lines
1 stearing collum bearing
front bearing assemplies
front hubs and two rear and 1 front drive shafts
currently parked with a busted transmission housing
Lost count of the hubs replaced during break repairs
I work it kind a hard ya think?
Would it be worth going with a 2003 or older with a 7.3 over a 2003 and newer with either a 6.0 or 6.4, despite differences of 100 000 miles or more?
174,xxx
um ha lets start.
GEM
transfer case. long story
clutch
new front end tie rods.
t-case motor ESOF
rebuilt turbo
seals on HPOP still leakin oil ugh n now i think i got a fuel leak.
GPR it didnt fix it :( ha
starter ^ from that problem.
o ya um ICP
front drive shaft.
things i think need to be done.
injector 8
driver side wheel bearing, brakes.
rear diff pan rusty.
cant figure out why truck pulls left!
possibly some Glow plugs.
figure out where oil is coming from
prob more. but. i got truck for cheap. so ya
7.3 is the toughest engine ever built for a pickup hands down. The question is every thing around it that supports the drive trane. I hate the 2004 we had at the shop.
Alright. Was looking at a 2003 with 200 000 km on it (125K miles) that had been treated like a princess it's whole life, with zero body and frame rust, and the thing is a fully loaded XLT minus duals & clearance lights. Thing is listed for $17 500, is this reasonable? What price range should I expect to have to pay for it?
Sorry if I'm getting off topic here.
97,000 miles-had the water pump replaced,header replaced,three transmissions.
On the third set of batteries.Runs super no body problems.The Ford trans in it now seems to be a good trans.
