21 - 40 of 457 Posts
Re: Whats your mileage on your 7.3 ? and with what repairs???
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Deeprobe</div><div class="ubbcode-body">Just turned 54K on my 2002 7.3 CC SWB. Low mileage due to my retirement from a back injury. Truck just sits in the driveway for the last three years.</div></div> Wanna trade??
Discussion Starter #22
Oh yea and my mpg 16 most all of the time!!!! /forums/images/%%GRAEMLIN_URL%%/grin.gif
Purchased at 114,000. Now 120,000. Since I have had it:
Starter, CPS, Fuel filter element, oil change.
281k on the '99. Ball joints, tie rods, lockout hubs, one front hub assy, water pump, tranny rebuild (@265k), GPR, glow plugs, fuel sending unit (got stuck), CPS, starter, fuel shutoff orings, other than that just routine brakes, shocks, etc.
90k on the '02. Just the CPS since I bought it in Jan.
87,000
tranny
auto door locks
tranny cooler
all brakes and roters
115,000
auto hubs
CPS x 2,now have new gray one
both front hubs
all seals in front axel
batterys
138K
Lube slip joint on drive shaft, brakes, shocks, GPR, alternator, batteries, fuel valve at filter bowl and soon to be O rings on HPOP.
141K averages 16.3 mpg. only normal maintance and o ring replacement
73k.
Ball joints
Batteries
CPS
GPR.
Other replacements were due to the lift (tires, shocks ect)
Well I'm at 625,000. Repairs- just about everything that is listed by others. Just saw a post from a hot-shot driver, showing 667,000 before engine died. My truck is still working for a living, and making money at it. Great truck to bad they don't mak'em like that anymore.
73,000 miles , rotors, brake pads, turbo pedelestal o rings, thats it great truck.
72,000 Miles.... Fuel Drain Valve O-Rings, Lower Alternator Pulley, Shocks
85K ,so far other than oil,tires,brakes,etc.I have replaced 1 hub assy,1 turbo (due to oil leak,non servicable seal),ball joints,and rear diff cover.
2002 model with 17k and have not replaced anything yet. Keep it in 6th gear and under 2000 rpms and it gets around 20 mpg highway. Towing 12k it will get maybe 12-13 mpg.
That is some really low mileage.
What part of southwest va are you from? I am from Speedwell VA which is about 12 miles south of Wytheville
215K on truck as of today.
BTS trans at 120K
Water Pump at 135K
IPR at 140K
Upgraded brakes see signature at 115K
Dinatrack conversion at 140K
My dad has a 95 with 650K miles with just the normal stuff replaced.
135K , solid 20mpg hwy , 15 around town and country.
Repairs:cps , gpr , tires , brakes.
About to go through brakes all around and basically rebuild front axle minus carrier bearings and gears , shocks , tie rods , bj's , unit bearings , hubs....tires(4)....etc ..about three grand worth of parts.
99 F250 2wd, 180,000, water pump, cam sensor(2x), brakes, and now need to change tie rods and so forth. Looking for info. About 19-20mpg. West Texas dirt here.
'01 F-250 4x4 with 68,000 miles. Gets a regular 17mpg empty.
Fuel drain o-rings replaced at about 60,000.
Driver's side front hub bearing replaced at 58,000.
Still has original Steeltex tires in good condition.
684,377 miles. 1 set of injectors, 2 waterpumps, 3 alternators, 1 starter, 2 CPS, 1 IPR,2 sets glow plugs, 2GPR, 1 turbo, 1 Tranny, fixed for good with a BTS, u-joints, 2 sets diff bearings,1 fuel pump,2 sets of rotors, and pads front and rear, 4 sets of rancho shocks f&r, gotta love lifetime warranties, ICP sensor, and preperation H.
