How do you tell if the wheel bearings are bad? If you remove the rotor and turn the hub should they make any noise? Do the leak greese when they start to go bad?
My truck has a bad pull when braking. The dealer has replace a ton of parts but has been un able to fix the problem. I think it is the wheel bearings.
