I tried doing a search on oil changes but no results were returned. My apologies if this subject has been previously discussed.
2015 F250 6.7L... With these newer computer controlled engines, the computer wants to tell you when to change the oil, but that may not be good enough for me.
A little background first. I use my truck mostly in the summer, pulling a fifth wheel trailer, and moving from place to place, out here in the West. I am frequently in locations where there are no Ford dealers or otherwise competent diesel oil change businesses. Therefore I need to plan my oil changes, if I can. 50% of our miles are towing.
Last summer I changed to oil in the middle of Colorado at a dealer, even though I had only 5000 miles since the last oil change, with the computer telling me that an oil change is not needed. I then drove straight to Yellowstone, to spend a week, with plans to drive straight to the Southern Oregon Coast afterwards. This was almost 2000 miles with no opportunity to stop for half a day to get an oil change, let alone finding a place to drop the trailer first.
If I can predict when I'll need an oil change, then I can plan for a down day to get the oil changed. Knowing how the computer determines when the oil needs changing would be nice. Does it do it strictly on miles driven, a combination of towing miles and non-towing miles, a measuring of the dirt in the oil, etc? Then once you get the alert about the "oil change needed", how far can you drive (towing?) before damage might be done to the engine? Does driving on unpaved roads affect the number of miles between oil changes?
Right now I've got about 7000 miles since the last oil change, so I'm expecting the alert to come soon. We have a short, 350 mile towing trip coming up in 2 weeks, maybe the alert will come then.
Thanks.
I typically change my oil between 5,000 and 7,500 miles depending on what I am doing with the truck. Aside from fuel dilution (which you should not experience on the open road and towing), the oil holds up pretty well in these 6.7L engines. If you are short tripping the truck on a frequent basis, you will like have some moderate fuel dilution and that can be a good reason to change it early. I have UOA'ed a few of my samples and the ones where I was towing look really good even out to 7,500 miles. For information, I am only using xW-40 oils and have tried most of the majors (Rotella T6, Delo 400 LE, Mobil Delvac ESP1, & Kendall Super-DXa) and have had good luck with all of them--I especially liked the Mobil (5W-40 full synthetic) and the Kendall (15W-40 Synthetic Blend). I have also tried Delo XLE in 10W-30, but did not care for it.
Hope this helps!
Reactions: ArcticDriver
If you have a smart phone, you can install free or paid version of Torque Pro, along with a Bluetooth OBD adapter, and you can display complete info on oil life. Distance since last oil change, % oil life remaining, along with many other gauges like EGT sensors, coolant, transmission temps, Alt output, etc.
Reactions: McGuire4
