1 - 12 of 12 Posts
With Michigan's cold weather coming,I am thinking about installing a grill cover for faster warm-ups. Where can I buy one? Anyone have good/bad experiences with these?
I used one from Lund and did not notice any difference in warm up. Basically, it will warm up at the same rate as long as the t-stat stays closed. Bob Riley's 203° t-stat will help. If you cannot keep it operating at the desired temp then consider the cold or winter front. The best cold fronts are made by Alaska Tent & Tarp. Look here. BTW, the coolant filter plumbed as Bob Riley depicts is the biggest impediment to warm up but he probably didn't notice any difference in Florida. I also have deleted my EBPV and at least so far have no issues warming up.
I have considered buying on as well. I don't know how much it would help though. It seems there must be an easy and inexpensive home remedy to this with a few items picked up at Home Depot. Obviously there is the cardboard solution, but I would prefer not to look quite that ghetto.
Anybody have any suggestions?
I use the Lund winter front inserts, and I have the summer ones to keep rocks/bugs out of my rad/AC condenser.
It made a huge difference for me. There were times last year when I could drive across the city in stop and go traffic and not get heat in 45 minutes of driving. That's with me parking in a heated shop btw. I added the front and things got much more comfortable.
The Lund covers were around 70 dollars for each one from what I remember. Money well spent IMHO, and they don't have the ugly look of the tarp style ones above. You can barely tell there's anything there.
Elliot2...
Have used both the Lund inserts for cold and the stainless steel cover for bugs, rocks etc. They worked well until I put on a tube grill cover and a bush guard. Now it is too much work to put either on, so PM me if you want both or either at a reasonable cost.
Good luck!
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Blk88GT</div><div class="ubbcode-body">I use the Lund winter front inserts, and I have the summer ones to keep rocks/bugs out of my rad/AC condenser.
The Lund covers were around 70 dollars for each one from what I remember. Money well spent IMHO, and they don't have the ugly look of the tarp style ones above. You can barely tell there's anything there. </div></div>There is a BIG difference in temperature between Winnipeg and SE Michigan. Our winters would feel like a warm spring day there. I agree if you cannot maintain normal operating temperature in winter a cold front will help but I just did not see any difference in the rate of warmup with a cold soaked engine with or without the cold front.
Discussion Starter #7
It sounds Like minimal help for faster warm-ups.I have a 203* t-stat and a remote start.I guess I'm just being a baby! /forums/images/%%GRAEMLIN_URL%%/cry.gif
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: haul_n_horses2</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Blk88GT</div><div class="ubbcode-body">I use the Lund winter front inserts, and I have the summer ones to keep rocks/bugs out of my rad/AC condenser.
The Lund covers were around 70 dollars for each one from what I remember. Money well spent IMHO, and they don't have the ugly look of the tarp style ones above. You can barely tell there's anything there. </div></div>There is a BIG difference in temperature between Winnipeg and SE Michigan. Our winters would feel like a warm spring day there. I agree if you cannot maintain normal operating temperature in winter a cold front will help but I just did not see any difference in the rate of warmup with a cold soaked engine with or without the cold front. </div></div> Well I live in Winnipeg and have never had a heat issue. This truck is the best winter vehicle I've owned. Dmax requires a winter front but these Fords don't. I would only consider it for highway use when it's -30 or worse. Then being cheap, I just put a piece of cardboard in front of the rad. /forums/images/%%GRAEMLIN_URL%%/smile.gif
Discussion Starter #9
I see alot of Dmaxes with black mesh covers.
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: haul_n_horses2</div><div class="ubbcode-body">There is a BIG difference in temperature between Winnipeg and SE Michigan. Our winters would feel like a warm spring day there. I agree if you cannot maintain normal operating temperature in winter a cold front will help but I just did not see any difference in the rate of warmup with a cold soaked engine with or without the cold front. </div></div>
We saw -55c for a week last winter. That's when I put the winter front on. I'm no meteorologist, but that aint no spring weather.
Discussion Starter #11
That's what Haulin' was saying when comparing our much warmer climate to yours.If Canucks can get by then so should I!
I must have read it wrong, my bad /forums/images/%%GRAEMLIN_URL%%/smile.gif
1 - 12 of 12 Posts
