The vent for the rear end is hanging. I know it attaches to the frame somewhere.
Does another line attach to the fitting?
That's the rear or front diff vent, that's how they are terminated from factory.
It just hangs on the frame rail , you can extend them if you do any 4X4ing or if just daily driving you just cable tie it to the frame rail (chassis)
I see some serious rust happening George?
I plan on removing the dually bed and putting a service body on. Then I can address the rust issues and probably replace brake lines.
Eventually I also have to replace the oil pan. Glow plugs, turbo pedestal, fuel lines.
I finally have the truck running right. Gauges are next.
I drive the truck everyday so I don't have time to do it all at once.
Like Googs said, the vent fitting just clips to the frame rail (driver's side in both cases, IIRC). Your clip probably rusted away. They're spring steel.
