1 - 19 of 19 Posts
Where is the Aux input jack on the 2015 F350. I have looked everywhere I can think of. I have the Media center on top of the dash. It as every kind of jack that you can think of, except Aux input.
Yeah, I checked the manual before posting this. It shows a picture of the jack but it doesn't say where it is. Not on the dash, not in the console, not in the media center. Where can it be hiding?
If it has the high end Sony system it doesn't have an aux in. My 2016 f250 doesn't. Just the media centre SD slot, 2x usb ports and the RCA left right connections which is the aux in for the radio. I had an RCA to din adapter and plugged my portable Sirius XM radio into those.
Sent from my Moto G Play using Tapatalk
Wow! A $65,000 truck with no Aux in. Even the cheapest Hyundai has one. The RCA to din cord was plan B. I have XM radio in the truck but my Lance cabover camper blocks the antenna. I have not found a reasonable way to remedy that situation. My idea was to install an XM vehicle kit and use my home radio with a magnetic antenna on the hood. Or bring lots of CDs.
For the Sirius that is. Should be able to disconnect factory antenna and plug in the mag mount
RoadrunnerII
I have over 25,000 mp3 files split between two 128GB flash drives plugged in the USB ports.
I do the same with my Fusion. It's nice having my entire library on board. Also, high capacity thumb drives are not all that expensive and I bought a low profile or compact drive so it does not get int he way.
Any pics of your media center? Seems odd that yours is "missing" RCA inputs. I got the Sony system using an RCA-3.5mm jack adapter working great. Just ran the cable to the console for my input.
Discussion Starter #11
No, I have the RCA jacks. Ordered the adapter cord and putting in my XM car kit and magnetic antenna on the hood. Found a cool mount for the car kit that goes in the cup holder. Regarding antenna input under dash on drivers side, I believe that they eliminated that in 2015. I have searched and searched for it. Somebody posted a bulletin a while back that shows it behind the radio. No way am I going to try to pull the dash and wiring apart. With my luck, nothing would work after that.
My 2016 has the antenna connector drivers side just above e brake. I know it is there because I used it for my portable Sirius XM radio
RoadrunnerII
It is the yellow plug with orange clip. It is mounted on the support just to the right of the emergence brake
RoadrunnerII
Discussion Starter #15 (Edited)
OK, found it hiding in plain sight. Looks like you can pull the yellow plug and orange clip holds cable in plug? The cable for the magnetic antenna has a right angle plug, so I'm not sure that this will plug into the yellow Ford plug. I see FAKRA adaptors advertised online. Do I need one of these? Sorry for the dumb questions but I had shoulder surgery a few weeks ago and can't use my right arm to reach up and fiddle with the plug.
I bought an extension did the reverse of what you are doing. I used the Ford factory antenna with my portable Sirius radio
RoadrunnerII
Discussion Starter #17
So the cable that I see going into the yellow plug is the cable to the factory antenna - correct?
The plug end is the antenna end. Cable I bought plugged into it (male end) and I ran it up to the Sirius radio. To use a different antenna with the factory Sirius as in a magnetic mount you would need a gender changer. Use it to convert the magnetic mount antenna male end to a female end. Otherwise you have to pull the center stack of the dash apart and swap the antenna behind the factory Sirius radio. The attached pic is the end you need to connect with. It goes to the Sirius radio
RoadrunnerII
The end connected to the brace is the connection my cable went into to use the factory antenna with my Sirius portable unit.
Hope this makes sense now
RoadrunnerII
1 - 19 of 19 Posts
