I seem to be have sensor issues thruout the engine... is there a site that shows the location of the sensors on the 95 models? I am now looking for the location of the BARO sensor...thanks
Here's some pics from Bill Millers album that should help you locate it:
Pic #1 Pic #2
And this is from the 94-97 FAQ:
Barometric Pressure Sensor
Strategy input; PCM uses this to adjust fuel quantity and injection timing for optimum running and minimum smoke, also glow plug on time to aid starting at higher altitudes; 5 volts in, @ 4.6 volts/14.7 psi at sea level, decreasing as altitude increases.
Have a2000 f250 diesel and looking for the barametric sensor. Where is it????
From 99 and up, the BARO sensor is located inside the PCM. Why are you needing to find it?
