Anyone tell me where the block plugin heater is on 99 F350 ? Never needed it before, but yesterday in Ohio it was 7* Hunted for it as good as I could in all the snow and ice .
· Super Moderator
It should be somewhere around the front drivers side tow hook. You can also follow the cord from the element that is located just above the oil filter.
Jim
As noted above, it is in the area behind the driver's side tow hook. The plug has a cap over the prongs and (if it has not been used before) will likely be wire-tied to the wiring harness/frame. Make sure to use a heavy-duty cord to connect the heater. The heater draws ~1,000 watts or about 8.3 amps at 120v.
Thanks guy's . Temps are rising here, maybe I can get it started and move it out of the snow. Cord must be tied up yet .
