1 - 9 of 9 Posts
Greetings all! This is my first post on this forum. I just purchased an 86 F250 SuperCab with a transplanted 7.3 IDI. The VRV is broken and the PO has the vacuum line connected directly from the pump. Where can I buy a new VRV?
Jeff
Welcome to the Diesel Stop.
Your probably going to have to scour the www as the C6 transmission in a diesel truck was discontinued in the 80's and repair parts aren't stocked for ever. I would try LMC truck on-line. If you can get a part number you can call a ford dealer, ask for parts and they can search inventory nation wide.
I just shipped the last one I had to Victoria Texas yesterday. Scoured ebay as I had seen one on there awhile back, it's gone. U-haul hasn't got one either. Your best bet is a junk yard now
When and if you do find one, make sure the drive pin on the throttle shaft is like the pic, pic shown is for a TPS , but the pin has to be the same way.
I dug out my VRV info. If you can't find one in a junk yard, you can have a dealer search nation wide, they can do that even if they say they can't'.
Here is the Ford PN For the VRV.
83 to 86 C6 GREEN CAM E5TZ7B200A
87 TO 94 C6 YELLOW CAM E7TZ7B200A
I know for a fact that site sponsor Tousley Ford will do it. I've been on the phone with them as the parts guy told me where a part I was looking for was.
They go by AutoNation now, white Bear Lake Ford.
Yup, they are really accomadating, talked to Mike several times.
If you can't find a VRV, you could install an E4OD.
Thanks for all the suggestions and help. I was actually able to track one down at a local little known salvage yard.
Lucky. Install it like my pic says.
1 - 9 of 9 Posts
