1 - 15 of 15 Posts
Mark Kovalsky reccomended the Mobil 1 atf for the 4R100, glad I listened- very happy with it! Can I also drain and refill my transfer case with Mobil 1 atf?
Mobil 1 is just fine
Mobil is fine I agree... so is Motorcraft Mercon LV. That seems to be the current go to replacement fluid for things like transfer cases and power steering and who knows what else... I would not put it in my coffee though.
Glen, it's a great idea to flush and fill your 4R100 transmission with Mobil 1 synthetic and use the same Mobil 1 in the transfer case. I have been running it well over 10 years and change transfer case fluid whenever I change trans fluid, why not, it just another couple of quarts. That way in my truck spares I don't have to have more than one kind of fluid to top off trans or transfer case should I have a roadside issue.
Discussion Starter #7
? more of a cream/sugar guy myself ?
Thanks everyone— got to try out my 4wd for the first time this morning. My Father (78) slid his 1967 F350 dumptruck off the road and down the ditch couple days ago after a light snow. The 2002 F350 7.3L pulled it out like it didn’t even know it was hitched (tow rope) to anything.
Discussion Starter #8
Thanks Oneof6, that’s what I was thinking—I know a lot of guys don’t seem to care for the TS-6 chip, and I was a little concerned at first after installation—- but after the flush and fill of Mobil 1 it’s a whole different animal and the TS is working great! My truck is all stock.
Noticed you’re from mid Alabama, Kathy and I are heading down to Gulf Shores December 26th — hope the weather is nice
Actually that is not accurate. Here is the specification:
Not accurate?
So you are saying that the currently active and up to date link from the FCSD (Ford Customer Service Division) Chemicals and Lubricants webpage, which I posted a photo of above, and also posted a direct webpage link to so anyone could see for themselves.... is inaccurate? You are saying that Ford is currently publishing incorrect information online right now to advise their customers on how to service their Ford vehicles?
And in the meantime, you are posting specifications that Ford last revised 17 years ago, in 2001, which identify a fluid specification that Ford hasn't licensed for over a decade? After previously suggesting a transfer case fluid "MerconLV" , when Ford's current fluid recommendations, as revised in 2018, suggest that Ford's "Transfer Case Fluid" is the preferred replacement lubricant for older transfer cases where Mercon was previously specified?
Can you provide more current links, from Ford, to support your assessment of Ford's recommendations?
Enough members of this and other Ford truck related forums have reported transfer case damage after using Mercon V, so getting accurate information benefits everyone. I used Mobil 1 full synthetic ATF in my transfer case for years without issue, when Mobil 1 was Mercon only. When Mobil 1 changed their synthetic ATF bottle to say "Mercon V", I stopped using Mobil 1 ATF in the transfer case, but continued to use Mobil 1 in the transmission, because Ford changed their fluid spec recommendation for the 4R100 from Mercon to Mercon V.
Interestingly enough, if I were to only go by outdated service manuals, Broadcast Messages, OASIS data, and TSBs from 2001, there would be plenty of official language from Ford advising AGAINST using Mercon V in the 4R100. Early FordDiesel.com (the precursor forum of TDS) will remember Mark Kovalsky's (former Ford Automatic Transmission engineer, now a Moderator here on this forum) strong admonitions against using Mercon V in the 4R100. But that was back in 2001. Fast forward to today, and Mark K's signature says something to the effect of "Ford hasn't licensed Mercon since 2006. Get over it."
Pulling up old service manuals that specify outdated fluids that haven't been licensed for over a decade... doesn't strike me as instructive to anyone seeking advice on what the right fluid is among the choices available today. Back then, Ford didn't produce the product called "Transfer Case Fluid." Ford recommended Mercon. But Ford did not recommend Mercon V for the transfer case, even though many a Ford dealer technician serviced the NV271/273 transfer case with Mercon V, apparently not knowing any better, or not keeping up with Ford's revised recommendations.
There had to be a reason why Ford created a brand new product after the demise of Mercon, and called this product a very simple and straightforward name: Transfer Case Fluid. Ford further spelled out that this Transfer Case Fluid should be used in transfer cases where Mercon was previously specified. I'm not sure how Ford could have been any clearer.
Yet you suggest Mercon LV in these older transfer cases, even though Ford says that Transfer Case Fluid should not be used in applications were Mercon LV is specified... which to me does not necessarily rule out the use of Mercon LV, but at the same time does strongly suggest an incompatibility in one direction at least, making all the more reason to just follow Ford's simple, and clear, and CURRENT directions to use Transfer Case Fluid in the transfer case.
Please point out where Ford is currently inaccurate.
For what it's worth, Ford's "Transfer Case Fluid" probably IS Mercon. :shrug03:
I have not heard of older t-cases being damaged by the use of MerconV. The fact that they're "older" may have something to do with failures, rather than the lubricant used. There isn't anything in a t-case that's all that sensitive, such as clutch packs, or yellow metal (synchronizers), to lubricant content, like there are in auto trannys.
Right. I am actually surprised that Ford still offers power steering and transfer case fluid any more. Oh, by the way, Mercon LV is specified "For use in all transfer cases" by Ford. Somebody needs to get their panties un-bunched.
Equally surprising might be encountering a Ford diesel senior master service technician who is unaware of what fluids Ford currently produces and recommends for Ford diesel vehicles, but given the age of the vehicle under discussion, it isn't. Here is the memo:
_____________________________________
May 18, 2007
To: All Ford, Lincoln and Mercury Dealerships
Subject: MERCON Automatic Transmission Fluid To Be Discontinued
BACKGROUND:
Effective July 1, 2007, the production and licensing of MERCON Automatic Transmission Fluid will cease. These actions are not exclusive to Motorcraft and affect all producers of MERCON. MERCON V provides significant performance improvements over MERCON especially with transmission shift performance at low temperatures and anti-shudder.
SERVICING FORMER MERCON APPLICATIONS:
Automatic Transmission, Power Steering Systems and Manual Transmissions previously requiring MERCON must now be serviced with MERCON V.
Transfer Case Systems previously calling for MERCON must now be serviced using Transfer Case Fluid, part number XL-12, specification # ESP-M2C166-H (release and TSB pending).
Power steering systems listed in TSB 07-1-7 can continue to be service with Premium Power Steering Fluid, XL-9 or F7AZ-3F823-BA (specification # WSA-M2C195-A).
Ford does not recommend the use of any products that do not meet the above specifications or ATFs that claim to be the equivalent of MERCON or being acceptable for these applications.
PART NUMBERS TO BE OBSOLETED:
XT-2-QDX MERCON Quart bottles
XT-2-DDX MERCON 55 Gallon Drums
XT-2-TDX MERCON Totes
XT-2-BDX MERCON Bulk
NEW PART NUMBER RELEASED EFFECTIVE AUGUST 1, 2007:
XL-12, Motorcraft Transfer Case Fluid Quart is scheduled for release August 1, 2007.
Please see your Motorcraft Ford Authorized Distributor or Bulk Oil Distributor for availability
PART NUMBERS NOT AFFECTED BY THESE CHANGES:
XL-9 Power Steering Fluid
F7AZ-3F823-BA Power Steering Fluid
(RT posted this same memo several years ago on this forum in a post on this same topic)
Exactly... which is why I said "which does not necessarily rule out the use of Mercon LV". But when taking all of the information that Ford has provided in totality, there seems to be an incompatibility in one direction, where XL-12 Transfer Case Fluid cannot be used in transfer cases calling for Mercon LV. And since Ford already clearly directs that XL-12 be used in transfer cases that previously called for Mercon, is Ford anticipating that service techs would even consider Mercon LV instead of the XL-12 Ford calls for? There is enough potential for misinterpretation of one sentence for me to stick with what Ford clearly recommends.
This is neither instructive nor constructive.
Just use AMSOIL and all problems solved!>:)
DENNY
or shaeffer's :winking:
Just to update this old thread:
Motorcraft "Transfer Case Fluid" (XL-12) is no longer manufactured or even available on the web.
Ford now recommends the Motorcraft LV for the Transfer Case in vehicles where XL-12 had been recommended.
Another option is the Valvoline Synthetic Transfer Case Fluid:
Another option is the Royal Purple Synchromax Fluid:
1 - 15 of 15 Posts
