Mine is starting to go bad. the truck is a 94 is all of the obs pumps the same cause i can ge tone off a 97. any input would be nice
i am pretty sure that all hpops are interchangeable from 94.5 to 03. but the superdutys have a 17* vs the obs 15*. i am also pretty sure that the 17* has a bit more flow than the others.
hope this helps,
kevin
i know the sd pump will work but i do not feel like drilling my engine to make it work. i want a direct bolt on.
But if you are going to go with stage 1 injectors someday like in your sig. Just get the SD pump. PM sent.
o0o thanks. i really just need to get the truck back on the road.
