Have had my 2000 F250 7.3 CC 4wd for about a year. Just recently (several times) I've noticed that after I've started up and driven only a few hundred yards my headlights and dash lights get brighter all of a sudden. Haven't done any diagnostics yet, but maybe this is a known problem?
John
It is normal. The glow plugs will stay on for up to 2 minutes and during that time the alternator has a hard time keeping up with the amperage draw from them. When they shut off that is when the lights will get brighter. If you also watch the volt gauge on the dash you will notice that it will stay quite low for the same amount of time.
Thanks bugman. That makes me feel better. Now iI wonder why I don't recall seeing it until recently. That makes me feel worse again... maybe I'm getting old...
Perhaps it's more noticeable in cold weather?
The cold weather might affect it - First, the glow plugs stay on longer based on oil temperature at start up. Second, the batteries are going to be weaker in cold weather and the load of the glow plugs probably pulls them further down. It theoretically could be an early warning sign your batteries are going south.
Might suggest your batteries are getting weak. Hard to know what is going on w/o a set of gauges. Might be a good time to invest in a scan guage 2 or an edge insight. They plug into the computer port and tell you all temps, volts and some pressures. Well worth the money in my opinion.
Discussion Starter #6
Not surprisingly, I'm not familiar with the "scan guage 2 or an edge insight". Where does one get them?
