like the title says im starting to worry that my chip will hurt my pump or injectors i already fried my tranny with the chip now im not gonna hurt my engine the tranny killed me for a while.
Any chip is taking time off the motor... Each Block has a set amount of HP hours... the more HP you make the less hours it will last... But in the long run does it matter? NO. Fuel pumps can go out at 10k or 200k... ya just never know... Injectors will last 200-300k if you keep good clean fuel going to them.
The pump runs at the same speed independent of the programming. Just depends on voltage. The best way to keep your pump alive is to make sure you do not suck air through it and filter the crap out the fuel you purchase. Hence 3/8" hoses to the Dahl filter and to the pump with minimal restriction. Don't ever run the tank down unless absolutely necessary. Similarly provide a good supply of air free fuel to the injectors and they will last a lot of miles.
