I have a 2008 F-250 Superduty and am looking to buy some wheels. I like the looks of the Eagle Alloy 064's in Black. The size i want is 22x10 with the 8x170 bolt pattern but the websire says they wont fit because of the offset of -20. From what i know a negative offset means that the wheel will stick out further...so the wheels should fit correct?
Also im planning on running 35's with these wheels, will this fit? I want to run them on the truck for a while, i do plan on lifting it or leveling it in the future but want to get the wheels and tires on first.
They will fit on there but without at least getting a leveling kit your gonna have some good rubbing I think.
hmm..i like when the tires stick out past the fender but i dont want mcuh rubbing...a little is ok but i want to be able to actually make a tight turn. I think i might do those rims and tires with a leveling kit and if it rubs badly ill go for a bigger lift kit. Do you think they would fit and not rub with the 6" rize lift kit?
