i have a 01 f 550, drivers side floor wet when it rains, seems to be windsheild, problem is when it rains, radio will come on by itself, heater blower motor also, if the switch for the heater is on, key off and out of switch, now also starter has engaged , when raining, can see that ecm and fuse box area are showing, signs of water, anyone had this problem, manual trans and truck drove through garage door by itselft parked in gear, no key and doors locked, neighber called me , and told me what was happening, wasnt home. insurance having hard time believing waht we told them. :icon_mad:
Very common problem for the windshields to leak on these trucks. Some leaked from the factory, but most common for it to leak with a bad install by someone who doesnt take the time to lay a nice thick bead of adhesive. After you get the windshield replaced get a new fuse box.
If you have clearance lights on the roof, before you spend the money on a windshield guy pull your head liner and run a hose over the roof, we just had a F650 that was leaking from clearance light and actually running along the windshield seem an down the A pillar, dehind the dash, and over the GEM sensor and fuse panel. The truck would START ITSELF in a hard rain!! And oddly enough, the headliner, inside of windshield, dash, and door would remain completely dry! I wouldn't have beleived it if I hadnt witnessed it myself. We actually stripped the headliner and A pillar trim and watched the water flow straight to the GEM sensor.
