1 - 8 of 8 Posts
I was wondering if anyone had an electronic copy of a wiring diagram for an 06 F-250 with the 6.0?
Wiring diagram for which part of the truck? What are you working on?
Radio 12v lt. green/purple + radioharness
Radio Ground black and black/lt. green - radioharness
Radio Ignition pink + radioharness
Radio Illumination lt. blue/red (dimmer) + radioharness
LF Speaker +/- orange/lt. grn - lt. blue/wht +,- radioharness
RF Speaker +/- white/lt. grn - dk. green/org +,- radioharness
LR Speaker +/- gray/lt. blue - tan/yellow +,- radioharness
RR Speaker +/- orange/red - brown/pink +,- radioharness
12volts yellow (30A), lt grn/pur (30A) + ignition harness
Starter dk. green + ignition harness
Ignition red/lt. green + ignition harness
Power Lock pink/yellow (w/o keyless) 5wi driver kick, door harness
Power Unlock pink/lt. green (w/o keyless) 5wi driver kick, door harness
Lock Motor pink/black 5wi driver kick or VSM, gray plug, pin 1
Unlock Motor red/orange 5wi driver kick or VSM, gray plug, pin 7
Disarm Defeat pink/orange 5wi pass. kick or VSM, gray plug, pin 8
Parking Lights+ brown + switch or VSM, green plug, pin 2
Parking Lights- N/A
Hazards same as turn signal wires
Turn Signal(L) lt grn/wht (F), lt grn/org (R) + turn signal switch
Turn Signal(R) wht/lt blu (F), org/lt blu (R) + turn signal switch
Door Trigger use dome supervision wire
Dome Supervision black/lt. blue + pass kick or cluster, blu plg, pin26
Trunk/Hatch Pin N/A
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm N/A
Factory Alarm Disarm N/A
Disarm No Unlock N/A
Tachometer NOT red/lt green or red/yellow ac any ignition coil or fuel injector
Horn Trigger dk. blue - switch or VSM, green plug, pin 6
I'm looking for the wiring diagram for the instrument cluster and radio. Everything periodically turns off, then withing a few seconds comes back on. This includes speedometer, temperature gauges, tach, fuel... everything, and the radio goes off during that time. Any recommendations or observations would be appreciated.
For anyone to help you, information about your truck or the truck you are working on is needed. Until you do this nobody has any clue as to what truck you need help with! If this is your own truck I highly recommend adding the details in your signature which you have not set up yet. Go to Account Settings by clicking on the icon in the upper right corner and then select Signature listed on the left. Type in the details and click save. Add information including the Model year, model, engine and transmission as well as any modifications you may have done. If this is not your truck then simply adding the information to your post is sufficient.
Mine is an 06, F250 with a 6.0 diesel engine. I apologize for being unclear. I thought the thread was about that particular vehicle. I sure would like a little help though.
1 - 8 of 8 Posts
