2000 Ford F-250 flatbed 7.3L power stroke with a 4 way chip and 6 spd manual tranny. 285/75/16 A/T
does anyone have the wiring diagram for the trailer lights cause i took the box bed off my truck and most of the wires for the trailer plug were broke. I would like to try to re wire it or if there is a way to unplug a connector and put a new one in.
The trailer connector plugs into the bed harness and you could just replace that whole assembly. You might find the setup with both 4-pin and 7-pin connectors at a wrecking yard or buy a new one from Ford (I think etrailer.com also sells something that would work). Unless you're into splicing wires.....
Here's the one you need from etrailer.
