Mark, good to have you back. Your departure was noticed a few years back when rumor had it a certain unnamed truck manufacturer didn't like your after work online activities. Looking at your thread history you've been back for a while, but this is the first post I've seen of your for a long time.It's either the brake light switch or the solenoid that keeps the shifter from moving out of park.
It wasn't really Ford's fault.Mark, good to have you back. Your departure was noticed a few years back when rumor had it a certain unnamed truck manufacturer didn't like your after work online activities.
No it won't. There is no override by pushing the brake pedal further. What happend on your truck is that the brake light switch was working when you pressed the pedal further.In a pinch you can press very hard on the brake pedal and it will overide the switch to get into gear.
Check the 5 amp fuse in the #15 position inside the vehicle. If it's blown, you can't shift out of park, electric windows don't work, interior lights won't come on and wipers don't work. If that's the case look for the sensor on the master cylinder. It'll probably be soaked in brake fluid. Quick fix is to disconnect the sensor and replace the fuse. Next get it to a Ford dealer and they should fix it for free under the recall for the cruise control. Hope this helps.i have a 2003 F-350 6.0 lifted and chipped it will not shift out of park while engine is running but if you turn key to ON without turning engine over it shifts just fine any ideas?
I just replace the solenoid body in my 07 f250 yesterday and after we got everything buttoned up and fluids back in my truck wouldn't shift out of park I am currently doing what you said I touched a brake switch loose but I tried to attract by turning the key over and then put it in neutral but itIt probably isn't the solenoid. Do your brake lights work? Most often the problem is the brake light switch.
You might want to re-word the post.I just replace the solenoid body in my 07 f250 yesterday and after we got everything buttoned up and fluids back in my truck wouldn't shift out of park I am currently doing what you said I touched a brake switch loose but I tried to attract by turning the key over and then put it in neutral but it
Won't move it all
Mark, my husband has a Ford F350 2015, yesterday it was running rough and wouldn’t accelerate Over 50 mph, unless he shut it off, the. It would work a few minutes and the problem returned......This morning it was dead and brake lights would not go off. He found and replaced a sensor... now it starts, but won’t shift out of park.... what should he do, and could the acceleration issue be related or just a bad coincidence.It probably isn't the solenoid. Do your brake lights work? Most often the problem is the brake light switch.
