1 - 15 of 15 Posts
I got it today and installed this afternoon! All I can say is wow. I really wasen't expecting this much with just stock injectors. I got a multi-pos(3) chip with...High idle, Tow(the same milage burn I've seen lemon boy post about), and a extreme burn. I've tried both edge and superchips tuners but they don't even touch this thing in my book. Anyways I think I lost a few thousand miles off the tires in the hour or so since I got it in!! /ubbthreads/images/graemlins/phoney.gif /ubbthreads/images/graemlins/phoney.gif /ubbthreads/images/graemlins/cool.gif
Sorry I just had to spread my joy!!!
/ubbthreads/images/graemlins/smokin.gifyour getting every thing that your injectors can give with Tony's power burn /ubbthreads/images/graemlins/biggrin.gif....have you noticed the different shift patterns? It holds the shifts up higher in the rpm range....that burn makes it fun to drive.....spread that joy, nice to hear you are liking it!
1994 PSD ext cab 5spd 4x4 Gutted ebpv ,Valeo smf and clutch,
/ubbthreads/images/graemlins/tongue.gif /ubbthreads/images/graemlins/wink.gif
/ubbthreads/images/graemlins/phoney.gif Did you notice how YOU hold your shifts up into the higher rpm range? /ubbthreads/images/graemlins/tongue.gif /ubbthreads/images/graemlins/tongue.gif
/ubbthreads/images/graemlins/cool.gif /ubbthreads/images/graemlins/cool.gifGrat aint it!!
bet you just ridin around in extreme huh /ubbthreads/images/graemlins/wink.gif
change yer sig. /ubbthreads/images/graemlins/biggrin.gif
Not me! I'm not the type to flaunt the new found power............. /ubbthreads/images/graemlins/cool.gif /ubbthreads/images/graemlins/cool.gif
What kind of boost are you seeing?
Discussion Starter · #10 ·
Thats one thing I am questioning. I was pulling the gooseneck flatbed empty last night after I installed the chip. Got on it in forth up to about 31-3200 rpms and was only seeing 21 lbs boost. Now stock loaded pulling like that the most I could get was 18 lbs but I was expecting a little more... any comments???
Without injectors I don't think you would see much more than that /ubbthreads/images/graemlins/shrug.gif
Discussion Starter · #12 ·
Thanks!
4th gear, empty, wot 26-7 psi, 5th wot 31 psi. pre 1.0
Not sure on the pricing, but you can reach Mr. Tony at 405-818-6365. He is a good guy and will take good care of you.
1 - 15 of 15 Posts
