WVO and WMO fuel incompatibilities
I destroyed my first injector pump about 4 years ago. At the time I was not sure what I was doing wrong, but after destroying several other injector pumps, and getting a fair amount of sludge in my fuel tank. I believe now I have figured it out.
Up until two years ago I had been filtering WVO into my fuel tank, then adding gasoline (petrol) on top of it. I finally took a jar of my filtered WVO and added gasoline (petrol) to it and let it sit. Within minutes a dark fluid precipitated out of solution. I concluded that the adding of gasoline (petrol) to settled and filtered WVO caused some contaminants to precipitate out of solution, which accumulated at the bottom of my fuel tank, until a critical moment, when it got sucked into the injector pump, which glued it and the injectors shut. So, I switched to blending external to the fuel tank. It then took me about a year of experiments to discover that I had to give the blend about 24-48 hours for most of the contaminants to precipitate out of solution.
Recently I explored WMO blending to understand the process better. I began with blending external to the fuel tank, and waiting three days for the precipitates to settle out, then I drained the sludge and filtered the blend into the fuel tank.
At the time I extracted a sample of the filtered WMO-80 fuel in two half-gallon (2-liter) bottles. One bottle of WMO-80 I blended with a sample of my previous fuel blend, which was WVO-80 blend. I let that 50/50 blend settle for a few days then poured off the dark liquid to see if there was a precipitate. Indeed there was. It was black goo at the bottom of the bottle accounting for about 1-2% of the solution.
Most of the time I burn a blend of 80% WVO and 20% gasoline (petrol). It runs fine indefinitely. Then, immediately prior to each injector pump failure I had added a small amount of petroleum oil to the blend to see how well it would work, but in each case it plugged my injectors and damaged my injector pump.
It turns out there is an incompatibility between filtered WVO and WMO. Therefore there are two possible solutions:
1) If I am going to blend WMO, then I should blend some WVO into it to cause the precipitate to form prior to filtering.
2) Run WVO-based blends in one tank, and WMO-based blends in another tank.
Note: I found the precipitate sludge dissolves in lacquer thinner, and possibly other solvents. I am experimenting now and will give you my results.
So, my solution to not dropping my fuel tank for the 4th time to flush it out after this blending disaster is to add lacquer thinner to my fuel tank along with the current blend and hope that the sludge will dissolve into solution with the fuel blend and burn as fuel. Since the sludge produced by blending WVO with WMO accounts for about 1-2%, and it is soluble in MEK, and I made a 20 gallon (80L) batch, then I plan to add 1/2 gallon (2L) of MEK to my fuel tank.
What is this precipitate?
Some have speculated that the precipitate produced from blending WVO with WMO is "polymerization." I believe a more simple explanation can be found in considering that WMO is a saturated solution of free-carbon in a petroleum distillate. When WMO is added to a WVO solution with gasoline (petrol), the petroleum distillates and vegetable oil blend readily into solution; however, vegetable oil does not have the same capacity for dissolving free-carbon as petroleum distillates have, so the free-carbon precipitates out of solution. There might be other components in either the petroleum distillates and/or vegetable oil that also precipitate out of solution that form the precipitate into a sticky, rubbery substance.
