1 - 20 of 22 Posts
Hey all!
You have probably all heard it suggested that if you are carrying any spare parts, one of them should be a CPS. Well thank you all very much for the advise, it paid off for me!
We had hauled our travel trailer from Seattle to Glacier National Park in Montana (West Glacier) and were making one of our many trips between the West Glacier KOA and the park when the truck bucked or jerked once, the power came back on and then died about 4 -5 seconds later. Died dead. Watched the tach when cranking and there was no movement. Waited a few, having heard they usually come back to life a few time before they are really dead, no luck. Crawled underneath with my spare and a 1/4" drive ratchet and 10mm socket and swapped it out. Fired right up and our friends were impressed that I diagnosed it and fixed it without ever lifting the hood. Frankly I was a little chapped that a PSD will strand you so suddenly, no warning at all!
Anyway, after carrying that spare CPS for 3 years, it sure paid off. Having changed my before (put a new one in and carried the original as a spare) the 10mm bolt had been broken loose since the factory install. I do recommend breaking that bolt loose at home and just retightening it to a normal torque figure. Many have rounded the bolt trying to break it loose for the first time with anything other than a 6-point socket. Once it is normal-tight, you can change it on the side of the road should/when the need arises!
Hope this drives home the recommendation that many on this forum have made... carry a spare CPS!
God Bless and thanks for the advise! /ubbthreads/images/graemlins/smile.gif /ubbthreads/images/graemlins/smile.gif /ubbthreads/images/graemlins/smile.gif
TC
I have one and decided to install the newer one with the gold plated connector pins and keep the original as a spare.
couldn't get it off. hope mine doesn't crap out on me because I don't have a game plan on how to remove it.
Thanks for the reminder Tim! I have my old one as a spare, but it did give me a little trouble some years back, so I put a new one in...just in case.
Probably wouldn't hurt to get a new one, just for the reason you explained!
Hopefully your trip went well otherwise, as you must have seen some beautiful country!
How where those EGT's while pulling the trailer with that new intercooler install you did?
Dale
The CPS failed in my truck 3 weeks ago and I sure wish I'd had spare one on the truck. I think I'll be getting a spare CPS to stick in the glove box in the near future.
What are some other common failure items on these PSD engines that might be good idea to carry?
Power steering hose? /ubbthreads/images/graemlins/shrug.gif
Idler pullies...
What is a CPS? /ubbthreads/images/graemlins/shrug.gif
· Banned
Cam Position Sensor.
I don't have a spare and won't worry about it because I know all I have to do is flag down another PSD and they will have one! /ubbthreads/images/graemlins/biggrin.gif
would someone post the part number for this little jewel?
I carry a spare serpantine belt, but that is about all. Sounds like a great idea, thanks for the suggestion!
Camshaft Position Sensor (CPS)
(Ford) F6TZ12K073A, (International) 1821720C99 (below engine 375548)
(Ford) F7TZ12K073A, (International) 1825899C93 (above engine 375548)
Cheers!
While both part numbers are the same for [email protected] and the CPS is gold plated for the latter years,the reason they are different is the factory connector for 94-97 is silver,mixing silver and gold connectors will cause electrolisis and will corode away your connection.
They both will work. If you use the newer one, just put some dielectric grease in the connector! No corrosion issues!
I am sure that it would depend IF you have a perfect coating on both surfaces,not something i would gamble on.If you rought a connection it would leave you stranded,then you would have to replace the CPS and the connector,try finding one in the middle of the desert in nevada
Cheers!
ok, so what do you'all mean about the below enging number?
Thanks!!
This forum is awesome!
Discussion Starter · #16 ·
Dale!
Dale
Once we got off of I-90, we saw some of the MOST BEAUTIFUL coutryside there is! And yes, the rest of the trip went great. EGT's only went as high as 1,050 degrees, so I guess I need injectors, eh? /ubbthreads/images/graemlins/laugh.gif
Well, that was my story from our Disneyland trip in April. Twelve hundred miles on the road and the hose fitting blows while backing into the RV site!
Click here for post on p/s hose failure
Funny thing is that the same friends were with us on both trip and witnessed both failures. Friend's wife said I should quit carrying spare parts because the truck obviously knows what to blow!
God Bless,
TC
It is a closed connector, fill it up with grease. It will entrap the whole connector.
I have had one on for 3 years, in some of the worst conditions. The connector still looks new inside.
But hell, what do i know! It's your choice.
Guess i am paranoid about such things,afterall it is your truck to do with it as you will.The dealer told me not to use the later connector,so i listened to them
Will someone post a pic of the CPS location ????ty Don Fuzzy
Here's a link (thanks Renegade!) to CPS location pic: http://community.webshots.com/photo/30962836/45694045wmgDtW
Engine number refers to the engine serial number stamped into the block just aft of the oil filter and sometimes on a sticker on the High Pressure Oil Pump Reservoir (many times long gone). Cheers!
1 - 20 of 22 Posts
