5th Wheel Drivers License
6.8K views 7 replies 7 participants last post by  dunesday
#1 ·
I'm thinking on getting a 5th wheel. Right now I have a slide-in camper and once a while tow my jeep.
Do I need a special license to tow the 5th wheel a vehicle behind it? Will my class C license will do?
Since living in California I know that max length is 65' which I believe it not going to be a problem, not planning on a long 5th wheel.
#2 ·
Check with CA DMV to be sure but in Ohio for an RV you do not need anything but a regular driver license.
Amazing, isn't it?
Dave / Believer45
#3 ·
I'll go to their website to see if I can find any infor. Does anybody know off hand??
#4 ·
If your 5th wheel will weight over 10k pounds you need a special endorsement. Pretty easy to get. No medical required. However most DMV offices have no idea what you will be talking about. When I did mine it took longer for them to figure out what to do than actually do it and take the simple test.
#5 ·
#6 ·
Others have hit the main points:
1. fifth wheel less than 10,000 lbs GVWR = no extra licencing required
2. fifth wheel between 10,001 lbs and 15,000 lbs = an RV endorsement on your Class C license
3. fifth wheel over 15,000 lbs GVWR = non-commercial Class A license is required
4. fifth wheel towing anything = CDL with doubles endorsement
#7 ·
i'm originally from ca and i am almost positive if i read your post right you cannot tow 2 things behind your truck in california.
i.e. truck towing 5 er with jeep behind that....
or have i seen it done... i know in some states its legal but i dont think in ca it is... /ubbthreads/images/graemlins/smokin.gif
#8 ·
It's legal in CA if you are properly licensed/loaded/length/etc...
