Yep, the old trucks had negative arch springs. The design had to do with which way the axle moves when you hit bumps etc...
With a plow you will need an add-a-leaf or air bags. The problem with the old Twin Traction Beam suspension is that the camber changes radically with the plow on or off with a plain spring suspension. With air bags you can keep the same suspension height, and therefore the same camber angle year round by pumping up the bags when the plow is on, and airing them down when it is not.
ON EDIT, the post doesn't specifically say that he is using the truck to plow, only that he is looking for plow spec springs. If he only needs to raise the truck and isn't plowing, an add-a-leaf kit is fine.
