Hi,
2002 7.3L with approx. 200,000 miles. Generally very well taken care of truck that I have had since 2006.
For some background, I don't use the truck much anymore. It can go 1-2 months or more without being started, and 3-4 months or more of not being moved more than out of the driveway to access my RV. It always has a battery tender on it and the batteries are good. The long-start issue appears to have magically resolved itself, but I wanted to pick your brains to see if I may have a bigger problem brewing, or if this can be attributed to lack of use. I am starting to use it again since I know it’s not a good idea to let things sit.
Here is the info about the recent no-start and then long-start issues:
After starting normally and going to the store on 5/1/2025, I came out to a no-start condition. Seemed to have no fuel pump. Poked around a bit, popped the relay cover under the hood on top of driver’s side wheel well, removed and replaced what I believe to be the fuel pump relay (standard 5-pin relay), and the truck fired right up. So, seems like a failing relay or poor relay connection is a possible root cause. Came home just fine. After this, I parked it again and didn’t use it really at all until August because I was worried it was going to leave me stranded again and figuring it out was not a priority.
When I did finally go to use it, it started doing a very long start – probably a solid 5 seconds or more – definitely abnormal. It cranked fast (batteries good), then would fire just fine, idle, and run normally (man I love this truck!). I did a few engine stops and re-starts over the course of a day or two, and each time, it did a similar very long start. Note that in this time, I did not get any more no-start occurrences. On 9/6/2025, I installed a new CPS sensor just because, thinking maybe that was the cause of the no-start back on 5/1/2025 and maybe it could contribute to a long-start condition (no idea if that is even a possibility – I am thinking no). With the new CPS, there was no change to the long-start condition.
Then, maybe on Day 3 of using the truck more regularly, it began to start just fine!! It didn’t matter if I shut off the engine and re-started it immediately, or did a cold-start in the morning – it fired up within a normal, short amount of time. No more long-start!
Any thoughts? Do I have a bigger problem brewing?
I appreciate the group think!!
- Danny
- Danny
