I recently sold my F350 crewcab 6.0 that I purchased in 2011.. I loved my F350, it was paid for and I had many great adventures and memories in that truck. When I first bought the truck I did the bullet proofing minus the head studs. I did the EGR delete, BPD oil cooler, blue spring modification, FICM repair atlas tune, and I flushed the oil cooler with the VC9 before I replaced the oil cooler. I noticed that the IPR values were 82% over the past few years and I knew that the HPOP needed to be changed out. My HPOP died in March of last year. HPOP was reading very low and the truck sputtered and died in my driveway. I replaced both the HPOP and oil cooler (since I was already into the motor that deep) in April. I went on 3 long distance camping trips and one hunting trip since I replaced the HPOP and oil cooler and the truck ran great over the summer. I ended up selling the truck since I am 5 years from retirement. My wife convinced me to sell the truck and to get a new one. I ended up selling it to a very nice gal and the truck died on her. I was mortified when I got this news! Sounds like a crank no start issue, but the truck was running so well last summer. So, I met her and we looked at the truck so I could fix it. Seemed like the truck would not start when it got hot, but would start when it was cold. We started the truck and I hooked up my phone to the truck and I had what seemed to be normal values when she started the truck cold. I remember the HPOP reading 1400 at idle, then my phone would not give me any info on the torque pro program. IPR, FICM sync, ICP all stopped reading in the torque pro app. This would happen to me when I used the torque app occasionally and decide not to read every few years. I would have to uninstall the program and then install it to get the program to work. We hooked up another app and I saw the IPR reading 84.7% and ICP pressure of 350ish. Last time I saw this on a 6.0, it was the IPR with a clogged screen. I had the original IPR in my garage. So, I replaced the IPR with the old one that i ha flushed and put new O-rings on and now the truck will not even start??? I plan to go back and see what readings I can pull from torque pro to figure out what the problem is. I bought the HPOP from CNC machine and the oil cooler was from BPD. I can not believe that the new HPOP is leaking, especially since I ran the truck all summer without any problems. The HPOP was from CNC Machine. I assembled the HPOP correctly, I put the yellow O ring on the bottom of the pump and torqued everything to spec. I ran an air PSI leak test before I swapped out the HPOP and I found no leaks in the system. I really need to get some numbers from torque pro for the IPR, IPC, FICM, RPM and such to see what's going on.
Where else could I have a high psi leak on a 2003 6.0? I am hoping it's the IPR valve. I tested the IPR that was in the truck for ohms and it registered 5.7 ohms. If I remember correctly, it should have 6ohms, correct? I hope to go back to test the truck to see if FICM sync is reading 1 with 48V. If not, I'll be looking at the wire loom. I am hoping for an "easy fix", especially since I had done an air pressure test last year with no leaks evident to me. Any thoughts and/or help is greatly appreciated. I really wish to pass on my truck to this nice gal in working order!
