2006 Front Super 60 Rebuild and Upgrade
38 views 2 replies 1 participant last post by  TKOPerformance
#1 ·
For anyone who's been following my high performance 6.0 engine build on another thread this is why I haven't gotten that project finished yet. Some years back I had bought an E-Locker for the front axle and never got around to installing it. I had an issue with the rear end that ended in me completely rebuilding the 10.5 SRW axle in the back. I used a set of Yukon gears (stock 3.73:1 ratio), a Detroit TrueTrac, Yukon master overhaul kit, a solid pinion spacer (no crush sleeve), I rebuilt the stock hubs, and reused the stock axles. FWIW, the issue with that axle was that years ago I had installed an upgraded Traction-Lok differential from Yukon (it was a rebuilt Ford unit with better clutches, which I don't think they offer anymore(though they do sell an upgraded clutch kit if you ant to do it)). This unit had served pretty well, but was worn out. My plan was to install the TrueTrac in its place and move on, but I discovered that what had happened was that some side shims I installed when I installed the first diff had managed to partially become dislodged allowing the backlash to open way up, and leading to a very disconcerting clunk that I had thought was just coming from the diff itself. Once I realized what was actually going on I knew the whole rear needed to be rebuilt. At this point it had about 290,000 miles on it as well. Just wanting to start fresh I just replaced everything. Of course about 10,000 miles later the engine locked up on cranking. I probably should have done a tutorial on that rebuild, though it was fairly uneventful. I did switch to Yukon carrier shims that lock all the shims together to hopefully avoid the cause of the failure.
While I had some down time on the engine project I decided to go through the front axle and install the E-Locker. Boy I'm glad I did, because one of the axle shafts had a u-joint which would have grenaded the first time I put any meaningful amount of power through it. I figured it was easier to work on the front axle out of the truck, so I pulled it. Looking everything over I decided to just go through the front axle, steering, and suspension and start fresh. This way the front axle and front end have essentially zero miles on them when the new engine is installed, and I can enjoy driving the truck for years before I'll need to do much more than change the oil and filters.
I didn't feel the need to install new gears in the front axle, because there was nothing really wrong with the ring and pinion part of the axle. 4WD rarely gets used, so the mileage on that axle is quite low compared to the rest of the truck. I therefore decided I would replace bearings, races, and seals, and just reuse the stock ring and pinion. When disassembling the axle I discovered that for some unknown reason Ford decided to use a crush sleeve in a Dana axle. One of the Dana series inherent strengths was NOT using a stupid crush sleeve. A crush sleeve is only beneficial when they are building the axles on the assembly line. A solid spacer using shims to set pinion bearing preload will never back off, doesn't move under shock loading, and allows you to change pinion seal without the need to crush a new crush sleeve. Unfortunately you need a special solid spacer kit for the Ford Super 60 to eliminate the crush sleeve, because the pinion surface where the shims would go is farther back on the Ford specific gearset to account for the crush sleeve (ordinary D60s just use a couple thin shims). I bought this kit to solve that issue:
I had already picked up new carrier bearings, races, ring gear bolts, and shims when I bought the E-locker some years back, so I really didn't need a master overhaul kit. I found that Jeff's Bronco Graveyard has really good pricing on Super Duty drivetrain parts, and actually lists all the small parts, so I picked up pinion bearings & races, an oil baffle (no easy way to get the rear pinion race out without destroying this), an oil slinger, and a new pinion nut (those lock nuts are supposed to be one time use). Here's a link to their Super 60 page:
Now as I'm not changing the gears, and these gears came installed in this housing the factory pinon shim SHOULD work, but we'll see how that goes. I'm going to run a pattern anyway just to be safe. This is another area where Ford Super 60s are different from regular D60s. A regular D60 places shims under the rear pinion bearing race. Ford decided to go with a more typical shim location, under the rear bearing on the pinion. The only problem is that those shims are not common, and I've only found one place selling them. They are also not cheap, so I'm going to wait and see if I need to actually spend that money or not based on the pattern I get.
I decided to have the housing powdercoated since everything was apart and I was going to completely strip it down anyway. Crazy Coatings in Middletown, DE did the blasting, zinc wash, and coating on the housing. As per typical they do great work.
This picture is after I thoroughly cleaned the inside of the housing to remove any left over sand, etc., and installed the pinion bearing races and oil baffle. The jack stands have Prothane jack stand pads on them to avoid damaging the coating.
#2 ·
The next thing that needed to go in were new axle seals. I initially bought seals from Rock Auto (SKF) and an installer from Amazon for like $20. I quickly found out that those installers, which are EVERYWHERE (Amazon, eBay, etc.) don't work very well (in fairness possibly this is an issue unique to the Ford Super 60, as I'm finding several oddities with this axle vs. a typical D60) and I ended up just ruining the seals trying to install them because they do not properly support the seal. The seals are not exactly free either, the SKF ones were about $41 each. Not terribly happy I searched for a better tool and found one at Torque King 4X4. This is by no means cheap, but it is very well made and worked really well. I bought the tool and seal combo since I ow needed ANOTHER set of new seals. Both seals took maybe 10 minutes to get in with this tool, AND it sets them to the proper depth.
Note this is just the setup and the installer is not fully bottomed out yet. The black puck goes flat when it is. Here is a seal fully installed:
Reactions: bismic
#3 ·
Setting up a ring and pinion IME is best accomplished by making setup bearings and running a pattern. I've used a variety of tools over the years to try and measure pinion depth, which in theory can give you the right pinion shim the first time, but unless you are using the same gears in the same type of axle over and over and over again you end up spending more time learning how to set up the tool and read it correctly (and possibly STILL not getting the right pinion shim the first time) than you do just using setup bearings and running a pattern. Ultimately, regardless what any tool tells you the pattern trumps it, because the pattern is the true measure of how the gears mesh. I have a buddy that owns an off road shop and has probably setup up in excess of a thousand sets of gears over the years and that's how he does it as well. His advice is to start with the factory pinion shim, even on new gears, and go from there. I've set up probably a dozen sets at this point and that's how I've always done it as well.
Making setup bearings is pretty easy, just get an extra bearing for each bearing where you need to make a setup bearing. On the Super 60 you will need 3 setup bearings (rear pinion bearing and both carrier bearings) because of where Dana/Ford locates the shims. These bearings are press fit, so you need to open up the ID of the bearing, which I have always done with a carbide bur in an electric grinder. It takes maybe 1-2 minutes of grinding per bearing to open up the ID enough to make it a slip fit. You can carefully clamp the bearing in a vice (clamp only the protruding part of the inner race just enough to hold it still), and then run the bur around the ID. I like to count to 30 while I do this, stop, check fit, and repeat as necessary. You don't want to go too far and end up with a sloppy fit. It should be just loose enough to get on and off by hand with no slop. I've heard of and tried, other ways to do this over the years, but this is IME the best and fastest way to do it. I've read about guys using brake cylinder hones or small engine hones. I did that for an hour one time and removed maybe 0.001" of material when you need to remove probably 0.003-0.005" of material. I don't recommend that route. Obviously thoroughly clean the bearing after grinding to remove any metal particles.
To set backlash you need a dial indicator and some type of holding fixture. I use a simple magnetic base fixture and dial indicator I bought at Harbor Freight probably 25 years ago. I had to make a new back plate for the indicator to allow it to be mounted to the fixture, but this setup has worked for every axle I've ever done, as well as for setting endplay on the shafts in a couple dozen transmissions, and cam & crank endplay in a dozen or so engines.
Another thing worth noting is that I do not bother with the pinion spacer to run test patterns. If you simply don't install it, and carefully tighten down the pinion nut (use the old nut for gear setup, then install the new one at final assembly so it only gets used once) until there is no slack, then start checking pinion bearing preload until you get it right; that will be fine for checking the pattern. I use an inch/lb. torque wrench to check the preload. I set it on the lightest setting (17 in/lbs for this axle) and tighten the nut until it just clicks. Then check it at the highest setting (30 in/lbs for this axle) and make sure it spins the pinion without clicking.
