Came in with forced idle, replace DPF pump unit due to wacked temp sensor, replaced both NoX sensors due to out sensor always showing higher than input. Clear ALL data and tables using Forscan and Autel. Attempt to perform TSB14-0192 to clear forced idle at least 50 times between myself and tech that works for me. This is a narrow frame (Non-pickup) truck. The step in the drive cycle where you get Ex 11 to 194 deg, Def pump comes up to pressure and I get one initial fat wave, bring to idle, drive 5MPH until square wave. I never get square wave!! Cant figure out why, Pump and injector works, and I will get duty cycle at other times but NOT when described during drive cycle. I have a sister truck (abet a 2015 instead of 2014) and have compared all data line by line and cant find any difference in parameters.
