2002 PSD 4x4 with 230,XXX miles. Mods: DPTuner, 6637, 4" exhaust, lift, 35s.
Driving back from a camping trip with my 5th wheel in tow I hit a glitch. We were pulling out onto the highway after we had stopped to eat. Some dude cut in front of me on the on ramp so I let out and got back in the throttle a couple times. It felt weird when I did that. Beyond what I did, it felt like it slipped and grabbed. At that point I start accelerating again (not hammering it, just accelarating onto the highway). I have now climbed past 2500 rpm...3000 rpm...3100 rpm. No shift. I let out and the rpms drop to near idle. Hit the accelerator again and they sweep up to 3000 rpm. At this point I'm on the highway looking for an exit. I'm at about 2800 rpm at 50 mph. I have no blinking OD light. I pull over...no fluid dripping, fluid is not hot, nothing obvious, nothing hanging under the truck. I check the shifter to make sure I am actually in D and not 2. That is fine. I limped the truck home between 45 and 50 mph. When I got to my 2nd stop light it wouldn't shift out of first. 35 mph and the engine was screaming. I let out and got back in it twice and it finally shifted to second where it stayed again.
Here are the codes I have. Nothing screams transmission, but the 1876 has me wondering. I was hoping to see a VSS code or something. Any and all help is appreciated.
P1876 - Transfer Case 2-Wheel Drive Solenoid Circuit Failure
B1352 - Ignition Key-In Circuit Failure
B1203 - Fuel Sender Circuit Short to Battery
P1211 - Injector Control Pressure Higher/Lower Than Desired (engine running)
P0476 - Exhaust Pressure Control Valve Range/Performance
I admit, I am fairly new to AE. If I have missed some sort of test, please point me in the right direction. Thanks again for your help.
Kyle
Kyle
