If my trucks been sitting overnight, it will start right up. If I drive it then turn it off, it will not start. I have to key on/off 5 or six times to cycle the fuel pump. It then turns over. When it happened before, I opened the fuel bowl and it was empty. It appears something is causing the fuel bowl to drain once the motor is turned off. Recent things I did;
1) filter has been replaced
2) fuel drain valve replaced
3) Blue spring mod
4) New filter cap (yes o-ring is on)
Any ideas? Thanks in advance
3) Blue spring mod
