6.0L no start, no crank with key
1 reading
14K views 8 replies 5 participants last post by  Lovin6.0
#1 ·
I've got a 6.0 2003 with 141k miles. Didn't use for a while and went to turn key and nothing. Some cluster lights went off. Just a click. Used the wire going to starter to start and it did. Shut off by itself. No start after. Now it won't start at all. Just replaced starter. Nothing
Discussion starter · #3 ·
If it cranks fine w/ the "wire going to the starter" then it isn't the starter.
Check the fan clutch connector and wires (you can even try cranking with this connector disconnected in case there is a short in the clutch itself). Also try to crank in neutral. Reset the inertia safety switch. Check fuse F2.22
I replaced fuse 22, I'm pretty sure it didn't pop again if it even did before, I pushed down on the inertia switch, didn't go down any more, neutral and move shifter didn't do anything, I'll check the fan clutch if I can find it.
