Apologies for this not being a Diesel question but I have a major hassle brewing in my 96. The rear door lock on the driver side was getting hard to move and I put off opening up the door panel a couple of weeks due to work load...big mistake.
Does anyone know a trick to opening a rear door that is locked?
The lock is frozen down and the rear electric solenoids are not even clicking or thumping. The front locks work fine and of course the fuse is good. I tried to put a 8-32 coupling nut with a bolt sticking up on the lock riser to pull with small ViseGrips. The riser is now 1/8-1/4" higher than normal. This is solid stuck. Getting the door panel off when door is closed is a real feat so I'm looking for ideas. I may have to drill a hole in the panel to poke a tool in and flip a lever. These old panels are precious as they seem unrepeatable and are not happy with being pulled off. I've owned this since new and been in the doors many times.
Regards
Regards
