My 97 Powerstroke when started it runs fine for a split second but then check engine light kicks on and it runs rough and the whole truck bucks and will die. If I get on the throttle it will rev up slowly and then come back down to an idle without dying, just running rough. Had the light checked no codes. Checked fuel pressure at the fuel bowl and it is 25psi. Could the pump under the turbo cause it? Sometimes it will come out of this and run fine for a few seconds but then back to running rough. The fuel pump isn't even a year old, hard to believe it is that but I am not sure. Any ideas?
