i heard john wood said the inline tranny filter is not nessessary. is that true?
Not exactly, but sorta. /ubbthreads/images/graemlins/cool.gif
Provided you have a brand new John Wood tranny and torque converter, and
provided he replaced the tranny coolers with brand new heat exchangers when he installed the new tranny, then and only then can you get by without the Magnefine in-line tranny filter.
Brian Thompson from BTS says the same thing.
But if you don't have a brand new tranny, torque converter and coolers, then you should follow Ford's instructions to their techs. Any time a Ford tech works on a 4R100 tranny, they are supposed to make sure it has a Magnefine filter installed in the cooler return line. If it doesn't have one, they add one. If it already has one, they replace it with a new one.
The purpose of the Magnefine filter is to catch any debris from wearing clutches or a blown-up torque converter or tranny before it can flow back into the tranny and cause even more damage. If the torque converter goes south, it will take the tranny with it if you don't have that filter.
Plus the magnet in the filter catches magnetic dust in the ATF. Mine captured about a teaspoonfull of magnetic dust in 30,000 miles. That gritty dust floating around in the ATF causes increased wear of the tranny parts, but it's too small to be captured by the stock tranny filter.
You can get the Magnefine filter at any Ford store, or online from
www.emergingent.com/magnefine - Click on "online store", then you want the $19 jobbie in the 3/8th size. Replace it every time you change the ATF. Remove it only if you get the $4,000+ Full Monte from John Wood, BTS, or Suncoast. /ubbthreads/images/graemlins/warmsmile.gif
what happens if you put too much tranny fluid in?
Nothing good. What Paul_B said. /ubbthreads/images/graemlins/frown.gif Better to have not enough than too much, but best is to make it just right. /ubbthreads/images/graemlins/cool.gif
