Coolant leak on 2008 F250 6.4L (lower radiator hose?)
I just bought a 2008 F250 6.4L (Job 3) with 50K miles. The truck is leaking coolant but only when cold and parked. It was sitting for about a year and started leaking about six months in. Once I topped up the levels and ran the truck the leak stopped but it just came back last night
It's dripping from the front center of the truck. I believe the coolant is dropping off the lower radiator hose but I haven't been able to get under there yet for a closer look. It could obviously be coming from somewhere else higher up and just dripping from there.
From what I've read, this sounds more likely to be a hose issue rather than a radiator issue. I'll be calling the dealer to setup an appointment but I was curious what the consensus might be. The truck is still under the powertrain warranty but I'm not sure if the cooling system is covered (it's certainly part of the powertrain but...). There is also a second extended warranty that should over it if it's the radiator and not just hoses.
Thanks!
Thanks!
