Engine missing
455 views 6 replies 4 participants last post by  realdann
#1 ·
It’s been a while since I’ve been on here. I have a 2000 super duty 7.3 and I replaced the engine with a Jasper engine.
With that said the first engine had a injector cup failure, and it locked up Jasper replaced the motor. Then then the second motor that was put in the engine was missing. I was pissed so I had the shop replaced the injector cups and the injectors with Motorcraft parts it still misses.
I also had them replaced the wire harness under the valve covers with OEM parts for the injectors and the wire harness on top of the motor. All Motorcraft parts.
It’s still Misses. I had a spare PCM and I replaced that and it still misses
Tomorrow, I’m gonna run it in to see if I can narrow it down to which cylinder or cylinders are missing with a heat laser gauge on the exhaust manifold.
The only thing I can think of is, I can narrow it down to which cylinders are missing. Maybe it’s a compression problem leaky valve seats that were junk right out of Jasper.
The engine injectors passes the buzz test. Any feedback would be appreciated.
#2 ·
Try a cylinder contribution test. If your scan tool can do an injector buzz test (which only checks the electrical side of the injectors - I assume you didn't get any injector codes or anything associated with the injector wiring,) it can also do a CCT. It's cheaper and easier than checking exhaust manifold temps. You can also get a glow plug adapter and do a cylinder leakdown test.
All that is cheaper than shotgunning parts at it.
#4 ·
Hello klhansen I have a laser temp gauge and the #1&2 cylinders are just over 100 degrees at the exhaust manifold. The other 3-8 are over 200 after a quick 1/4 mile drive. I appreciate the feed back. I can remember you on here helping out all the way back to 2003 when I got this truck
#3 · (Edited)
Also, you might try:
Check your wiring first, using and following this link:
Tech Bulletin 103
Then if the wiring checks out see if there is anyone near you that would have a spare IDM you could try and swap out.
I had an IDM with an intermittent short causing a miss and running on half a bank, along with several others on other forums I have messaged.
#6 ·
Do the Cylinder Contribution Test before you throw an IDM at it. A dead bank on the IDM would show up as a code on the Injector Buzz Test.
The more data you have, the better you're able to track down the actual problem.
A non-firing cylinder can be caused by lots of things. Low compression (rings or valves), Injector, Injector wiring, etc.
Exhaust manifold temps is a pretty rough test. A 1/4 mile run is really pretty short for that to give you good results. If you're going to do a manifold temp test, run it till it gets good and warm, then check. I'll bet you'll find them a LOT closer in temps.
