So, tonight I noticed that the front diff, and the steering dampener are wet with what looks like fuel. So, after looking closer, I can see that most of the oil pan is wet, mostly towards the front of the engine, and its dripping onto the crossmember, then onto the diff housing and steering stabilizer and tie rod.
Any idea what would be causing this? It is definately diesel.
I wondered if it wasn't the fuel bowl/fuel drain o-rings, or if it wasn't something else. I looked in the valley between the heads, and no diesel there, and the HPOP under the fuel bown has some signs of moisture, but nothing is soaking wet.
The steel intake housing that sits on the cylinder head, looks to be a bit moist, but not sure if its diesel or oil, but it isn't soaked either.
It definately looks like the moisture runs from the front of the oil pan to the rear.
Also, I have some moisture at the rear of the block, on both sides by the bellhousing, not sure if there is somewhere where it can leak from the valley down back there without leaving a puddle in the valley.
I just swapped out the rubber flares on the hard to get pass side line that goes to the back of the head and to the pump, and it is still dry.
Any ideas? I need to get it fixed for a trip next weekend.
