Help! I have done so much to my truck & i cnt seem to get the temp down! Any info will help!
According to your sig you have a 7.3, the 7.3 oil cooler isn't as efficient (and doesn't clog as easy) as the oil coolers in the 6.0 & 6.4. My 7.3 runs hotter oil temps than my current 6.0, it also has 4.10 gears so it tachs higher on the highway too, that doesn't help. The OP should have a delta less than 15* when running 1900 RPM for 15 minutes empty and level.I didn't know 218* was high for TX heat.
