Need some idears here what could have happened. The truck was starting to run good, and now this. The only thing I did, today, was throw in some biodiesel mix and now the oil is leaking.
At idle nothing shows up. Kick it to high idle at 1200 rpm's and oil is leaking out the H2E outlet to the big turbo, and leaking out of the manifolds-to-up pipe connection. I'm not talking a little drip now and then. I'm talking 12" diameter puddle from idling at 1200 for 5 minutes. I took one manifold off and ALL the cylinders were soaked in oil. /ubbthreads/images/graemlins/confused.gif
If a turbo blows it's seals, how can you tell? Will it leak into the intake, exhaust, or both?
Exhaust looks normal, no blue I would expect from burning oil.
There's just a ton of oil coming out the cylinders that's not being burned. Idles good, runs good. I didn't drive it not knowing what's going on.
Not sure, or if it's even possible, the BioD wasn't combusting all the way and there's residual oil in there that needs out?
Looking for pointers here what to look for.
Thanks.
Thanks.
