Power brake hydro booster leaking rebuild or replace?
3.8K views 4 replies 3 participants last post by  Supercab79
#1 ·
Does anyone know if the hydro booster for the brakes can be rebuilt or do you just have to replace them.
Also is there a place online with a good price on a new or rebuilt unit?
Thanks Marc
#2 ·
Anyone? /ubbthreads/images/graemlins/shrug.gif
#3 ·
You can pick up a cheap replacement hydro unit from a salvage yard index I use. car-part.com make sure you put in the dash.
I searched for the unit you are looking for and found several for as little as $20.00 under the F450 column. You will need to read through them until you find ones that list the hydro unit because not all salvage yards employ skilled inventory listers /ubbthreads/images/graemlins/wink.gif.
Hope this helps.
p.s. keep this website under your favorites you can find anything you are looking for there.
Good luck, Eric
#5 ·
No 912504x4 was right it is for an f-450 it is the hydro boost valve not a vaccum booster. Thanks for the tip.
Marc
