i was wondering if its bad on the 4x4 or if its bad for anything? and also does the 4x4 still work?
Not bad, just doesn't function as designed. (read, no 4x4 unless you manually lock the hubs.)
The front knuckles are designed to to maintain vacuum so the hubs can be remotely operated. If the vacuum is leaking out 1) the hub or hubs will not activate (or partially activate... that's bad) 2) the X-fer case will engage the front drive line, and torque will be delivered to the wheel hubs, but since they're not locked, the wheels will not see any of this torque.
One caveat... if there is enough vacuum to partially engage the hub, when that torque is transmitted through the partially locked hub to the wheel, you will probably torpedo that hub (read launch it off the truck!) They are constructed mostly of plastic with a little metal sprinkled here and there for good measure.:icon_rolleyes:
