Thread sealant
4K views 5 replies 6 participants last post by  cdnsarguy
#1 ·
#3 ·
#4 · (Edited)
#5 ·
FWIW I have used the thread sealant with teflon liquid lots of times and it seems to do a real good job.
#6 ·
The liquid teflon I use also....it allows a good connection with the threads so you still have a ground passage on sensors ie Oil pressure sensor and the plugged filter sensor on the fuel header etc. The Permatex is best for flywheel bolts into the crank, water pump bolts etc anything entering coolant passages or oil use areas.
