Hello,
I have researched previous posts to resolve a vacuum problem to no avail. I am experiencing problems with my vent controls and AC. I have no AC and the vent is in the default defrost mode only. The vacuum pump is two weeks old and draws 22 in of Hg. The brakes are fine.
I pulled the passenger side head and replaced the head gasket three weeks ago. I am aware of the vacuum lines for the MAP sensor and vacuum plenum chamber on the passenger side as well as the the small white plastic vacuum line contained within the loom on the passenger side.
My problem is I can not locate where the vacuum line enters the cab through the firewall to feed the control valve for the vents and AC off of the plastic vacuum manifold located below the air filter. I have a mityvac and the desire to sort this out. Can anyone point me in the right direction?
regards,
regards,
