I've been trying to find a short for the past few weeks in the odometer/speedo and overhead light. It would blow the fuse. I found the short(the easy part). The short was caused by on disconeted bundle of wires under the dash. What I need to know is what this bundle of wires is for and how to reconnect. The only thing that does not work are the power locks and the light that come on when the doors are opened. The wires that were cut are located just above the shifter(standard) where there is a quick connect(quite easy to see, very low not up under the dash at all) I also found a black box which looked like it should have quick connect type plug on it at about the distance where the cut wires would reach. It it just above the gas pedal. The color of the wires are:
Red...10 gauge wire
Black...10 gauge wire
Green(light)...16 or 18 gauge wire
White...16 or 18 gauge wire
The "black box" has the id of VF2TB-10D840-AA with 7 tabs.
The wires appeared to be cut by the previous owner and used for something. I just want to hook everything back to the way it's supposed to be. And perhaps my door lights will come back to life.
Red...10 gauge wire
