After lots of searching not sure what to do. Truck has developed a temp sensitive issue.
A few days ago started truck and let it warm up about 5 minutes, headed into town. About 8-10 miles down the road truck suddenly dies, like turning off key. Tried to restart, no start, and no tach. Turns over good, oil level good, engine temp normal. Outdoor temp about 75F. Since no tach I swap the CPS with spare. 15 minutes later still no start, and still no tach. Called for a tow.
Truck sat a couple of hours, checked fuses, etc. Tried to start and it starts and run fine. I assume pulling and re-inserting fuses, etc. must have been it. Next day head out again, about 10-12 miles and back home. Left truck running went in house and about 3 minutes later truck suddenly dies, and no start again. I just let it sit a few hours, did nothing, tried to start and it starts and runs fine.
Today I just started the truck, let it idle for say 30 minutes and it dies. Then no start until it cools down.
Since this truck is 2000 I assume that no tach means bad CPS, or CPS circuit. But now two different CPS sensors behave the same, so maybe the CPS pigtail.?? I am sure it's not the CPS since the "cold" one I swapped on the road side did not fix the no start.
I am stumped with this no tach symptom.
I have read that the IPR can get temperature sensitive, but the no tach is confusing me.
Any ideas.??
Any ideas.??
