... 2000 ford f250 ...looking for some opinions on this setup to tow/haul SAFELY.
Ford engineers are the experts on the weight limits of your truck. They say you have a limit of 8,800 pounds GVW and 20,000 pounds GCW.
The 20,000 pounds GCW is probably no problem.
But the 8,800 pounds GVWR is a huge problem.
If your truck is a 4x4, then it probably weighs about 7,300 pounds when wet and empty. About 8,000 pounds with two people and only a few tools and other weight. That leaves only 800 pounds for additional payload.
About 450 pounds of your additional payload is taken up by the hitch weight of the jetski trailer. So that leaves only 350 pounds available for a slide-in camper.
Sorry, but the only thing you can haul per Ford is maybe a tent, a Coleman stove, a cooler full of cool, and maybe a "slop jar" for a pottie. /ubbthreads/images/graemlins/wink.gif
Some folks say the F-250 is almost identical to the F-350 SRW, so it's okay to overload the F-250 up to 9,900 GVW. If they're right, then you have a max of 1,450 pounds available for a camper. So maybe an empty 4-Wheel pop-up tent camper, but certainly not even the lightest slide-in truck camper. Or maybe a bed topper, plus the tent, a Coleman stove, a cooler full of cool, and maybe a "slop jar" for a pottie. /ubbthreads/images/graemlins/warmsmile.gif
Your next step should be to load up the truck with the loaded trailer and the folks and stuff normally with you when on the road. Go to a truckstop that has a CAT scale, fill up with diesel, then weigh the wet and loaded rig - driver, passenger(s), and all. Add the front and rear truck axle weights to get your loaded GVW. Subtract that weight from 8,800 and you'll know how much more weight you can haul SAFELY.
How about the auto trans...will this set up kill it quick, 77,000 miles on the truck. Somthing I could do to help it live...sort of anouther trans!
The tranny killer is heat. If you don't get the tranny too hot, it will live regardless of your load. So add a tranny temp gauge with the sender in the pressure port on the side of the tranny. Watch that gauge like a hawk when under high-torque, slow-speed conditions, and don't allow it to go over 225. Up to around 200 is normal. 200 to around 220 is not unusual when under high-torque, slow-speed conditions. But if you see 220, then get ready to find a wide spot in the road so you can pull over, stop, take the tranny out of gear, and idle the engine at 1,200 RPM or more until the tranny cools off to about 210 or less. And do NOT kill the engine when the tanny temp is over about 200.
If you ever see over about 205 tranny temp, then change to synthetic MERCON ATF. Do not use any dual-rated MERCON/MERCON V ATF. Be sure it's DEXRON III/MERCON or MERCON/DEXRON III. AMSOIL makes one, but it's not their normal "Universal" ATF that is dual rated including MERCON V.
