Sgnaz:
Nice write up on the cups. This is definitely one of those jobs were you will save over 200% by doing it yourself.
I went with a similar extractor from a guy in Florida who has an EBay store.
7.3 POWERSTROKE PARTS, 6.5 GM DIESEL PARTS items in angelofishes store on eBay!. He sells a complete kit that gives you the tool, cups, Loctite, and replacement O rings for the injectors.
Overall I wouldn’t call the job “easy” but it is doable. I think I got lucky with a few of the back cylinders since I couldn’t really see what I was doing.
In addition to draining the oil rail I also recommend pulling the most reward injectors first. This allows all fluids to drain into only 2 cylinders. This made evacuating the liquid easy preventing hydro-lock.
All in all, my job cost right about a grand. But that includes replacement ELC and a Dieselsite coolant filter which was on my bucket list and this was a good of a time as ever since the coolant was drained.
I also had to replace several hoses and the degas bottle since the diesel reacted with the rubber and plastic and damaged them.
My only recommendation to anyone trying this job is to flush the crap out of your cooling system before filling it up. Splice into a heater hose and hook up a garden hose, remove the thermostat and re-install the housing and run water through everything. Pull the block drains on each time and flush some more. Then run simple green through the engine. I used on gallon mixed with water. Many posts on here about people still seeing diesel in the coolant after this job. I think a lot of that can be contributed to not properly flushing and cleaning all the parts in the system. And with the high price of
ELC; nobody wants to have to drain that stuff and replace it 2 days after doing this job.
It did give me confidence for future jobs like injectors and anything else under the valve covers.
Thanks again for the write up.
