I know this is a elementary question, but where are the correct front and back jack points on our Superduties? I need to remove all four wheels, do some cleaning and painting.
I think you meant to say "Jack stands are imperative"Floor jacks are imperative. I lost an uncle back in the 60s to a floor jack that ruptured an o-ring while he was under the vehicle for a "quick check".
Your right they are different. the trailer ones are generally screw type with a small flat circle at the top, and the automotive type have notched stops and a "U" shaped head. I wouldn't use a trailer type on an automobile, but I would use an automotive type on an RV.Do you have actual jack stands that are designed for trailers or ones that are designed for cars and trucks?
I have a couple of 2 ton sets that have served me well for over a decade. I used a pair of 12 ton to hold the front axle of a '72 Winnebago, 37" off the ground to drop an engine. That 454 would lift the front end of that 27' motorhome off the ground when I was done. :thumbsup:Harbor Freight has the big 6 ton stands, anyone using those?
I don't mind putting a jack there on an unloaded vehicle but I wouldn't on a loaded one.I never, ever, jack any unit up with the jack under the gear box or "pumpkin" as some call it.
One of the fun things to do on this forum is split hairs, it is just that kind of media. We expand upon many things past a practical mechanical purpose sometimes, but this is not one of them. RT, you are a smart guy but are just defending a poor mechanical practice on this topic in my opinion. I think that if you re-read you own post above you will find where I base that.True - and I wouldn't think about doing it on a vehicle that had any significant weight in the back. On a pickup, usually you can get two guys named Bubba to pick the back up without jacks. To pick the back up with no torque applied to the axle tubes, you'd need two floor jacks one under each leaf spring lifted exactly the same amount at the same time. Just lifting one side at a time would exert a lot more force on the components than lifting it in the center.
I worked in auto repair shops, that had no lifts, for about 20 years. There were at least 10-20 vehicles per day that were jacked up by placing the jack under the center of the differential. That's 50-100,000 vehicles without any issues. I'd guess there are 1,000's of other people with like experiences. I'd also guess there is someone somewhere that has seen some damage by doing this.
I'd also guess there is someone who always leaves his window down so he can get into his car because he once slammed his finger in the door.
99% of the time when a owners manual tells you not to do something like jacking a truck up by the center of the diff is because they are thinking that you are doing it with a stock jack.The "link" to the manufacturers recommendation is in your owners manual. It states to NEVER use the center of the diff. either front or rear.
As far as the lug nuts are concerned I would like to here how many use an air impact to tighten there wheels or a torque wrench? I personally use a torque wrench.
