Any one know right of hand what the stand alone resistance of the MAP Sensor. I dont have any codes, nor do I have the check engone light. but I think the MAP Sensor is not operating properly. Truck acts like it is flooding itself and doesn't start.
I took it off and measured the resistance it came up .032 Ohms. Which to me seemed low. I read somewhere that it takes the 5 volts supply from the truck and changes it from 1 to 5 volts depending on boost pressure. 1 volt being idle, and 5 volts being max boost. If it is only supplying .032 ohms of resistance, then my truck constantly thinks I am at WOT which would explain the "flooding" and not starting.
Any suggestions would help.
Thanks in advance.
Thanks in advance.
